enable stpd
enable stpd {stpd_name}
Description
Enables the STP protocol for one or all STPDs.
Syntax Description
stpd_name Specifies an STPD name on the switch.
Default
Enabled.
Usage Guidelines
If you want to enable the STP protocol for all STPDs, do not specify an STPD name.
The following command enables an STPD named Backbone_st:
enable stpd backbone_st
Platform Availability
